[FOR SALE] Griffin Aluminum Radiator/Fan Combo
MICHAEL A SCUDDER
Newb
Greensboro NC
New in the original box Griffin CU-70027 22" Aluminum Radiator and 16" SPAL fan combo unit. Includes relay wiring kit.
For 67-72 A-Body small block automatic but transmission cooler provisions can be plugged for a 4-speed car. Griffin's website says it will work in some Mopar B-Body applications.
I was going to use this in my 1968 Dart GTS but since I'm using the original intake I don't want to drill and tap a hole for the temperature sensor and relay set up. I had my original radiator recored by Glen Ray Radiator.
I bought the Griffin set up new for $1200.00. The kit has gone up to almost $1400.00
Asking $850.00 pick up/meet up within 120 miles of 27408 ZIP.
Mike
Greensboro NC
You can buy a spacer that is threaded for sensors it's about 1/2" and goes on the thermostat. It's a Meziere #wn 0028U, about $40. I have one on a Gen 2 Hemi for a sensor on F.I.. Hemi's and B engines have no water in the manifold.
Thank you. I appreciate that info. I'm still going to use my restored OEM radiator.
