Grill Dilema
Dizzydean
Richland (Tri Citys) Wash
Good Day all. I have a 20 gal propane tank that I would like to run my grill with. Has anyone tried this with this size or bigger tanks,if so where did you get the hose to fit.Thanks for the help. Dean
Propane grilles normally include the hose with proper fittings and inline regulater. If you have a grille that was tied to a different supply there is /was a regulater in that line somewhere. Hop this helps
Thanks Red, I am trying to go to a bigger tank cause the 5 gal goes to fast plus I got the 20 for free. My Mr heater will fit so I could have garage heat all winter long.:cheers::cheers::cheers:
With the new regulations and dates stamped on the tanks there will be a lot of free bottles available. I have one that will be worthless at the end of May.
Good luck
