mrhinsjc
Active Member
At the Spring Fling in Van Nuys, CA there used to be a vendor that specialized in restoring grills. I think they are in the LA area. Does anyone recall the name of the company?
Enjoying It Again here. Do you have a forum already on how to do a restoration or who to contact to find out how? Much Appreciated.have you considered restoring your grill yourself...it's not difficult.
How does one restore a grill?have you considered restoring your grill yourself...it's not difficult.
I looked in the how to articles I can't find it. All I seen was the shark tooth grille fix and the barracuda trim painting. I want to paint my dart grille the right way I want the front to be argent and the inside black like its supposed to be how would one paint that? Would you have to tape off every single fin?check out the HOW TO ARTICLES (at the top of the page) as there is a write up there.
As post#3 said "King of Trim" I have them do multiple items from grille repair and restoration to dash bezel, heater control panel & glove box door for my 1972 Plymouth Scamp. They are great!At the Spring Fling in Van Nuys, CA there used to be a vendor that specialized in restoring grills. I think they are in the LA area. Does anyone recall the name of the company?
I'm doing it myself. Not paying someone.As post#3 said "King of Trim" I have them do multiple items from grille repair and restoration to dash bezel, heater control panel & glove box door for my 1972 Plymouth Scamp. They are great!
I dont see anything in post five that helps answer my question. I know it has To be masked but where and how what is the procedure? Does the black go first or the silver etc?read post #5
Under the “HOW TO ARTICLES” then go to Exterior & Body Work then the 5th from the bottom is about repairing a shark tooth grill. Tape every piece and yes a lot of work. Pick the colour that is the most difficult to spray or has the least most of tape. Just go for it.I looked in the how to articles I can't find it. All I seen was the shark tooth grille fix and the barracuda trim painting. I want to paint my dart grille the right way I want the front to be argent and the inside black like its supposed to be how would one paint that? Would you have to tape off every single fin?
