340wedge1971
is there a ground cable that goes to the body as well to the engine?I have a cable from the battery to the cylinder head,do I need to run one to the body?
There usually is a braided strap from the rear of the head to one of the heater motor mounting studs. At least there was on most of them I've torn down.
running stainless braided for the tranny cooler lines so I don't have that electrical path available.
thanks for that linkI'm rewiring my Dart and doing the amp by pass as described in the link below and I am going to run a ground from the battery to the base of the ecu and voltage regulator, any recommmendations on where to run a couple more grounds??? I'm running stainless braided for the tranny cooler lines so I don't have that electrical path available.
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
