Guess my ET....
B3422w5
Portage michigan
OK.... just formulated an offseason plan.
Race season is over for me
Here is what i have now...
Bone stock 360 shortblock
Stock rods, crank, replacement cast factory spec pistons(+30)
Howards mech flat tappet cam( 260/264 565/ 565... on a 106, in at 102
Dougs headers(d453)
Eddie heads, modest port work, would guess maybe 270-275 max flow... 58cc
Airgap
950 hp
4.30 gear
28 drag radial
904
5k flash vert
3300 ish with driver
Typical ET’s... 11.30’s in good spring/ fall air, 11.50/11.55 dead of summer air.
New combo
418 shortblock+40 340 block, 4 inch forged Scat crank, Scat rods, Forged flattop pistons( Icon) that are somewhere 5-7 above deck( have to check again). Likely use( after verifying clearance) a 45 cometic gasket. Somewhere 12.5/ 12.7 compression i am thinking
Gasket matched Weiand excellerator
Same carb
Same cam
Same heads
Same gear, tire, vert
any guesses on ET... good air/ summer air?
Dougs headers(d453)
Airgap
950 hp
4.30 gear
28 drag radial
904
5k flash vert
New combo
Same carb
Same cam
Same heads
I don't see how your combo could possibly make 950 horse, unless you forgot to mention nitrous/blower/something.
Its been a best of 11.26 before. That was with a 727. I swapped in a 904 hoping to see an improvement on the slip, but best ever is 11.33 with the 904.
Obviously i missed on the convertor.
I am hoping to see about 5 tenths. Figure the cubes and compression are good for 3-4 tenths.
Figure this new deal will like a 260@ 50 cam much better than a 9.5-10 to 1 360 did. And i hope the new motor will be more suited to the convertor. We will see. Hoping for 10.75 ish.
I would say... in good air.. sea level. 10.40's@126-129
mine is pretty close to that, although cam is a little different. I'm still tuning and it's running 11.2's @7000ft da (so far), which would easily put mine in the 10.7ish range at sea level. Either way, sounds like a certified ripper.
I would love you guys to be right.
But the car is 3300 ish with me, and the heads are FAR from max effort
Thing is gonna weeze like a 3 pack a day 90 year old at probably the 1000 foot mark drinking air through a straw.
Dougs headers(d453)
Airgap
950 hp
4.30 gear
28 drag radial
904
5k flash vert
New combo
Same carb
Same cam
Same heads
.40 quicker in summer air. (11.10)
.40 quicker in good air. (10.90)
Don, your new build is similar to my old 408, 260/264° at .050, 106° in at 102°, .626/.633" with 1.6 rockers, 10.8-1, Curtis Boggs ported Edelbrocks, 727, 9.5" converter that flashed 5400, Victor with a Bigs 950HP, Hedman Husler 1 7/8" 3 1/2" headers, 4.10 S-60, 28" drag radials, Cal-Tracs and mono's.
It ran 6.57 @ 104 with 1.38-1.40 60' at 3260# on pump 93. I shifted at 6400 as it slowed down with anything over 6600 or less than 6400, it was running out of cylinder head. Dave Hughes said it would've been faster with a smaller cam, take that with a dump truck load of salt.
IMHO, you are going to run out of head sooner than I did. As you know I'm don't have much experience with 1/4 mile racing, but feel with your gear and heads it'll lay down on the big end. Your car works well so my guess is 6.70'-.80's, possibly .60's on very good conditions.
This and $1.75 will buy you a cup of coffee in some places. :thumbsup:
Looks very similar to my current motor as well, except you have a 904 (I have a 727) and my Eddy's flow 293 @ 0.600, and my cam is a step bigger (264-268 @0.05 with ~0.630 lift IIRC). The only thing I would do differently would be put a Victor on it.....With that said, it would not surprise me to see it in the 10.4-10.6 range (really depends on what the heads flow). We will have to see come spring time.
Edit: just re-read...I thought you were going to use an Air-gap, that is why I said switch to a victor...carry on.:D
