JGC403
So the plan is to build a 400 based 470 stroker for my '68 Barracuda. I want to start collecting parts for the project. Car will be mostly a street car, but It will see some track time.
Light rotating assembly is the plan.
For connecting rods, what would be better for my build? I used H-beam rods in my 408 and they are heavy compared to factory I-beams. They say H-beams resist twisting better, I personally have never seen a twisted connecting rod either. The factory used I-beam rods and they lived.
With a 400 block and a 3.915" crank the piston will be a lot lighter than a factory piston. So with less mass to control an I-beam should work. Is what I'm thinking.
Is it worth going to a chevy rod journal size and piston pin? Wanted to keep the 440 length rods, but if I can't find a stroker crankshaft with Mopar sized rod journal I will have to get shorter chevy rods.
Just started looking and there isn't as many I-beam connecting rod options as there are in H-beam. and the I-beams that are out there aren't cheap, even the chevy ones.
I had seen an article on some engine build, and found out about inboard piston pins thought those would be cool.
