http://www.speedcityresin.com/
'66 PLYMOUTH VALIANT "THE HAIRY CANARY"
" EASY IO ASSEMBLE "
#SC-28 .......... $42.00
THIS IS THE ONLY ALL CORRECT '66 "HAIRY CANARY" FUNNY CAR MODEL EVER CAST !!!
Mastered from an original '66 Plymouth Valiant promo model
Approved and Authorized by Rick Williamson Owner of "The HAIRY CANARY"
Unlike the other resin casting being offered as" the HAIRY CANARY", This is not a '66 barracuda with a washed out SIGNET roof............. THIS IS THE REAL DEAL !!!!
Although hard to see in the photo, the side chrome body trim is there, along with all the correct sail panel moldings !!!
This kit was desigined to build both (early & later versions).
To build the later version (lowered & set back engine) you will need to cut out part of the firewall & floorboard, build an L-shaped box in the interior tub to surround the engine & re-set the transmission mount.
A model king funny car kit will supply the suspension & interior parts.
For a steerable front axle, use a Revell '51 Henry "J"
Has Correct "HAIRY CANARY" decals for this kit
