mattmatthew
^_^
hi all, working on plumbing the front brakes in a drum to disc conversion (1965 valiant to 1976 duster front end). i'm a little confused as to what i'd need to have a well-working system - everyone seems to have a slightly different view on what's needed.
i came up with a simple diagram:
do i need to plumb in a stock distribution block as well? i have one from the donor 76. or can i run just the adjustable proportioning valve in the rear line?
the consensus on FABO seems to be plumbing the oem distribution block in plus the adjustable proportioning valve in the rear.
however, a number of other sources, including the mopar action online "stop on a dime" article and tom condran's book says to chuck the oem block and just splice in an adjustable proportioning valve.
what else will i need in there? a safety switch? btw i'm not building a race car, just want the discs to stop me better than the drums did.
thanks!
thanks!
