Hardened Seats for Big Block Heads
71-440-Duster
Northern Cal
Does anyone know when or what heads have hardened seats from the factory?
I have a set of 213 heads off a motor home and the casting date of the block is 1973 and wanted to know if I need to run with a fuel additive or not to protect these things.
Thanks in advance...
The you talk abot is a 3751213 head with 2.08&1.74 valves.these heads are found on the 400&440 motor home only motors.The heads with harden seat s started in 1973 with flame harded seats,not inserts.Mrmopartech
