[SOLD] harland sharp
they are at at imm engines socal they do not work on my motor that brian is building
so out they go
chubby, I have a friend who is interested but he says there's not enough part numbers to tell what they fit in the HS catalog. What is the application? PM sent too.
Interested, i'am about to call Brian next day or two about getting a motor done and need rockers. What application/motor are you building ? Why wouldnt these work for you? Thanks
410
they were not center on valves on rhs head could still have used them but would wear out valve stem seals quicker also went to 1.6
Thanks for the reply,I'm looking at havin the same thing built ,rhs la heads etc,so chances are gonna run into same problem, to bad good deal for someone, thnx
