hey people, ive got a few questions relating to stroking my 883 to 1200 on my '00 sporty. first, would i find any performance advantages with using 1200 heads vs 883 heads? (i would assume that 883 heads would have smaller combustion chambers?) anyone know how much it would cost to modify my 883 heads to work with the 1200 piston kit. second, does anyone have any or know someone who has a set of 1200 heads for sale. i found a killer deal on a 1200 piston kit but its the stock type piston kit so they say that i either have to modify my 883 heads or buy 1200 heads. so whats the opinions out there?
I did this years ago on the 99 Huggar I own.
OK after I did the exhaust, carb, and other stuff wanted the 1200s power. Most bang for the $$ you will ever see. it will be a completely differant beast when you are done.
I opped for the 883 heads to be modded. in Fact I have them on the shelve and will sell them for a good price if you want them?
Had to have the 883 chambers tweaked for the correct compression per Harley and the increased bore etc. Bike made very good power but I felt the top end was lacking.
so next I added Andrews N4 cams. Made better power lost a little bottom, but not much, still was way sronger even on the bottom than the 883 ever was.
Next the early sporters in the evolution line had a racing better ignition system that was on the susper sports. A much faster ignition curve, higher red line etc. This made the bike much more responsive, of course I had made minor carb jet changes with each change I mentioned.
I still after all this felt the top end suffered and sis not pull as hard as it could about 5k, and 6k on was a waste. I found a guy with a set of Buell heads. MAN Oh MAN what a diff! I also know the 1200s would make more power, but the other post about the quench is correct too. Long story short the Buell heads did not hurt the bottom end at all, power was up from 300 al lthe way to 6800. I never could pull this thing higher than 6k before with the 883 heads. I am sure if the larger valves and some minor port work the 883 would have been better, but not Buell performance.
If you just want a 1200 and not a huge $$ investment the modded 883s are the way to go, for a few $$ bore stuff the 1200 valves i nthem.
Anyway the heads had less than 500 miles and I have them boxed up. if you want these PM me I will make you a good price on them, you can use them as is or make them into 1200 valves too.
OK a few numbers and I have all the sheets packed up.
Stock the bike mde as an 883 no mods
56 rwhp
Exhaust carb twealks bumped base timing
68 rwhp
1200 bore kit and re-jet carb
82 rwhp
Ignitioned added and N4 cams
96 rwhp
Buell heads, more carb work, tweaked the ignition again
114 rwhp and torque up 40 ft lbs from stk
Other mod steps I added almost identical amounts of torque and hp.
Bike is one nasty Huggar, still says 883 on tank is a sleeper and a half. Idles about 1000-1100 very lopy and will run with almost any crotch rock till about 130. I have had the bike at 145 on a track. I kept the 883 sproketcs for the faster 0-60 pullying. This is my play bike.
I have a 2000 Road King Classic with a stage 2 big bore kit. This bike makes great power but is the wife and mines riding oturing bike.
