water pump, an alternator, and a very small oil pump to circulate oil to/from oil cooler. radiator fan is gong electric.
can't find widths or depths on the keys. anyone have one to measure?
i'm transferring torque from crank, through key, through balancer bolts, to pulley, that's welded to a shaft that uses 3/16" key twice before making the pump shaft.
I feel like the mopar is the same if not a bit heavier?
And shaved keys are ok. No broken crankshafts, right?
