In your case it depends on the RPM level you plan on turning. Whether you use stock or aftermarket, I'd buy a new one, because the rubber ring inside them degrades and will either fail (worst case), or give you inaccurate timing readings. Sounds like you've got some decent money in your new motor, why cut corners on the balancer?
