inkjunkie Well-Known Member Joined May 24, 2009 Messages 17,416 Reaction score 3,094 Location ...... Feb 11, 2013 #1 I know the shoulder harness's are just wrapped around the cross bar.....but what is done with the lap mounts? Just use the oe mount?
TrailBeast AKA Mopars4us on Youtube Joined Mar 11, 2011 Messages 22,779 Reaction score 12,651 Location Arizona Feb 12, 2013 #2 I attached mine on the same bolts as the factory belts on the floor between the factory stuff and the floor. Worked out fine.
flyfish C8H18+N2O = :-D Joined Apr 16, 2007 Messages 2,501 Reaction score 1,229 Location Indy Feb 12, 2013 #3 Yes, use the OE mounts. For the submarine belt I just drilled a hole in the floor and put a backing plate on the under side to give it extra strength so it can't pull through.
