wirenut
- Joined
- Sep 27, 2009
- Messages
- 300
- Reaction score
- 3
Looking for a 24' enclosed to haul my duster race car and track stuff. car weights 3k. found an add on cl for this from a place called APC equipment in AZ. Its factory pick up in PA for $5960.00 Let me know what you think.
2014, T/A, 7,000lb, 102x24 Haulmark Passport V-nose, Enclosed Cargo Car Hauler Utility Trailer
PPT85X24WT2
Steel Frame
Flat Roof
2-5/16in 10,000lb Coupler
48in Beavertail
Z Crossmembers
Crossmembers 24in On Center
2in x 6in Tube Main Rails
18in V-Nose
Hat Section Roof Bows
Roof Bows 24in On Center
1/4" Safety Chains w/ 1/4" Clevis Hook, Latch
Standard Height
84-3/4in Z Post
Vertical Posts 16in On Center
2,000lb Top Crank A-Frame Jack
Sand Pad
Standard A-Frame Tongue
4in Drop Arm
Wide Track
Breakaway Kit
Manual adj Electric Drum Brakes(req breakaway kit)
5 Bolt Pattern
Non EZ Hubs
1/2in StudsSpring Suspension
(2) 3,500lb Axle
ST205/75R15C Radial 5B White Spoke Wheel
Price Fighter Max Size Rear Ramp Door - Std Duty
16in Plywood Ramp Extension
3/4 Plywood Ramp Decking
32 x 72 Side Entry Door - Bar Lock/Recessed Step
3/4in Plywood Decking
3/8in Plywood Sidewall Liner
(4) 5,000lb Square D-Ring with Welded Plate
(2) 12v Dome light
License Plate Bracket w/Seperate Light
Incandescent Tail Lights
Incandescent Clearance Lights
12v Surface-Mount Switch
Polar White
.030 Alum Exterior
1-Piece Aluminum Roof
24in Starbright Stoneguard
Sidewall Flow-Thru Vents
http://westernmass.craigslist.org/fod/4384225738.html
as always any input appreciated
PPT85X24WT2
Steel Frame
Flat Roof
48in Beavertail
Z Crossmembers
18in V-Nose
Standard Height
84-3/4in Z Post
Sand Pad
4in Drop Arm
Wide Track
Breakaway Kit
5 Bolt Pattern
Non EZ Hubs
(2) 3,500lb Axle
(2) 12v Dome light
Polar White
.030 Alum Exterior
