grassy
Folks,
I have a vibration when the engine is running. My mechanic thought it was a engine mount on the frame problem but I have that eliminated. It is a 360. Af far as I know, everything is balanced. The torque , if I remember, was weighted...it was a Chrysler producd but I have lost the model number.
The only think I can think of is the torque converter...I thought of unbolting it from the flex plate and push it back...no vibration. ..then it is the converter..
Vibration still..flex plate..
That will not work...because the starter uses the torque converter to start the engine..
Is there any way else to test to see where the problem is ?
Should the car not be driven now ?
Thanks
Ian.
Thanks
Ian.
