Having no luck - 67 barracuda Hedman Hedders
Mopar Exhaust Systems
  1. MagnumBarracuda
    MagnumBarracuda Active Member
    39
    9
    Aug 20, 2018
    Valders
    Local Time:
    4:33 AM
    I am trying to install my new magnum 408 with Hedman long tube headers. car is a 67 barracuda, manual steering, manual brakes, manual trans. I have no clearance issues with them but i cannot get them installed. I tried putting the engine and trans in with the headers loose in the engine bay, no luck. My only problem is the passenger side header, It will not let the trans past. I can get the engine itself in and everything can bolt up but i cant get the trans and bell housing up high enough in the trans tunnel to bolt it in that way. I will try to bash the flange in the trans tunnel to allow the bell housing to move higher. Am i doing something wrong? Is there an obvious better way to go about this?
  2. 67/6barracuda
    67/6barracuda Well-Known Member
    674
    671
    Jun 24, 2013
    Sharpsburg, GA
    Local Time:
    4:33 AM
    Time for the BFH. Sorry no help, Good Luck!!!
  3. rustycowll69
    rustycowll69 Well-Known Member
    2,206
    1000
    Feb 19, 2016
    Pacific northwest
    Local Time:
    2:33 AM
    I don't know about your specific header, but I've installed several sets over the years. Usually the installation instructions which come with the headers will usually get you 80% there, but you have to be a little creative, yourself. I usually had to jack the car a couple feet in the air. Sometimes they go in easier from the top, but usually from the bottom. The starter will probably need to be disconnected and removed. The center link will probably need to come out, also. The oil filter may need to be removed, or in the case of rt angle adapter, the adapter may need to be loosened and possibly rotated. It may help to remove the washer & nut from the underside of a motor mount, and using a floor jack and a 2x4 on the edge of the pan rail, lift the side of engine by pivoting the engine over a little and buy you extra room. I think it is usually easier to install passenger side first, then the drivers side.
    Sometimes it helps to rotate the headers nearly vertical to get them in and then rotate them back level. It's a lot of trial and error. Sometimes a hammer may be needed, but once you do that, you can't return them, obviously.
  4. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    60,773
    32423
    Jun 7, 2010
    Georgia
    Local Time:
    5:33 AM
    Go on the Summit site and look the headers up. There is a PDF link with instructions.
  5. RustyRatRod
    60,773
    32423
    Jun 7, 2010
    Georgia
    Local Time:
    5:33 AM
    I could not find the Hedman long tubes on Summit. They may have quit making them. Look at the Summit brand headers that fit your car and download those instructions. They are bent the same.
  6. famous bob
    famous bob mopar misfit FABO Gold Member
    16,596
    6375
    Aug 14, 2011
    okla
    Local Time:
    4:33 AM
    I`m assuming ur working on a small block , but I had to jack my r/b 68 fastback up about 3 feet to get my headers on from the bottom/work the starter at the same time , and thats without torsion bars .
  7. MagnumBarracuda
    39
    9
    Aug 20, 2018
    Valders
    Local Time:
    4:33 AM
    Is it possible to remove the steering rack and replace once headers are in position?
  8. MagnumBarracuda
    39
    9
    Aug 20, 2018
    Valders
    Local Time:
    4:33 AM
    I have the instructions from hedman. They are very good for clearance and what not. The installation just says to go through the bottom.
  9. RustyRatRod
    60,773
    32423
    Jun 7, 2010
    Georgia
    Local Time:
    5:33 AM
    Then that's how you do it.
  10. famous bob
    16,596
    6375
    Aug 14, 2011
    okla
    Local Time:
    4:33 AM
    If ur talking about a rack and pinion set up , yes .
  11. MagnumBarracuda
    39
    9
    Aug 20, 2018
    Valders
    Local Time:
    4:33 AM
    Just the center link
