for those interested the basic package NOW includes.
fully tigg welded K-frame and componants including...
chromoly upper and lower control arms
4 Moog K772 ball joints (optional QA1 1" extended available for uppers only)
chromoly support hoops
upper shock mounts
three position ride height simulators
sway bar mounts (can be deleted)
HDK / Schumacher poly mounts of motor choice
Energy Suspension lower control arm bump stops
Energy Suspension adjustable upper control arm bump stops
Energy Suspension upper and lower ball joint dust covers
poly bushings, sleeves, spacers, and bolts for rack and pinion mount
Fat Man Gen II tie rod ends.
All hardware for above INCLUDED.
To ease installation, the K-frame comes out of the box assembled with the lower control arms, poly ends, jam nuts, ball joints, and shock bolts installed. The upper control arms are sub-assembled with ball joints, poly ends, and jam nuts.
you will need....
A) rack and pinion....................manual or power
B) spindles..............................Wilwood Pro 2" drop or standard Mustang II 2" drop
C) brakes...............................almost any Mustang II brake package that your rims allow
D) steering shaft, universals......choice of steel, stainless steel ($), or polished stainless steel ($$)
E) coil overs...........................the (included) ride height simulators allow you to visualize your desired stance and purchase the optimum shock for your ride.
