ARP gives you specs in the box to torque with their moly lube of 30 wt motor oil. My service manual says to torque them to 50 then 70 ft lbs. The sequence on top bolts from center bolt number 1. 5,9,13,17 to the left of number 1. 3, 7,11,15 to the right side of number 1. On the bottom bolts the sequence from the center bolt number 2, number 2 is to the right of number 1 on the top. It goes 2,6,10,14 to the right and 4,8,12,16 to the left. Hope this helps and it not confusing. Draw a picture of the bolt pattern.
:read2:
