Head gasket; seal or not
Westtexdart
Gentlemen please bare with me , this is my first small block rebuild. I'm about to install heads on the 69 340,(factory cast iron ). Gasket set from victor-reinz(Dana).I'm not sure if teflon or not. Gaskets are sort of grey color, part no. 5813G. Anyone know if I should use gasket sealer ?
If any decking or milling has been done, make sure the dowel pins aren't too long.
