Kevin D.
Can you use the thin .025 head gasket with small block aluminum heads? Your input appreciated,Thanks Kevin.
The MP ones are not shims, but thin composite. If you removed them carefully and they didnt stick or pull apart at all, sure. Just pay very careful attention to chasing the threads, using the right oil, torquing in steps, and torquing in the right order. If the gasket surfaces were torn at all, don't re-use them. Also, I dont think the MP gaskets are pre-flattened so you may over time run into brinneling issues with aluminum heads. That's when over time the steel ring around the cylinders wears into the aluminum head and loses sealing ability. It will wear a groove into the head in some situations.
