Greg Edsall
New Member
I have stock stroke 30 over 340 with older trw2332 pistons. I just got a deal I couldn't turn down on a set of trick flows. Just wanting know what head gasket to use?
If the surface of the block will allow it, Cometic is what I would recommend. Trick Flow also sells head gaskets that are made for them by Cometic that are basically the same gaskets.I have stock stroke 30 over 340 with older trw2332 pistons. I just got a deal I couldn't turn down on a set of trick flows. Just wanting know what head gasket to use?
No, Their a copy of the 10.5 68-70 piston. KimIsn’t that the TRW domed piston?
