Ok one more question about re-using gaskets. My motor was run for a couple minutes I need to pull the head off to put a helicoil in one of the exhaust manifold bolts. I have a new set of head gaskets, but prefer not pull both heads off. Does it matter if my head gaskets do not match? If it does can I resuse the used gasket so they do match. Thanks again
