aaronk785
OK. How many cc's will i lose milling my 915 heads .050.
.040 should be enough to make the average 915 about 63-64ccOK. How many cc's will i lose milling my 915 heads .050.
Mine are 59.8Thanks everyone. I'm trying to come in at 60 cc so I will go .050 and that should get me close. Yes I will shave the intake side .0475. Heads do have SS valves that are flat on the bottom so that should help a little. Thanks again.
you should remove 10.3ccs with a .050 in. cut if you dont touch the chambers, assuming a 4 in. bore in the chamber.OK. How many cc's will i lose milling my 915 heads .050.
Some shops want 200.00 to mill an intake.It cost more the more u have them milled. Simply because they have to make more passes to take more off. The intake side is another charge. Same goes with it. Kim
I had my SpeedMaster heads milled .031 and the intake milled I’m guessing .050-.060. It was outta wack b4 I had the heads milled. I never asked him. I traded parts to him so I only know what my parts were worth. Notice how far the bolts are outta wack. KimSome shops want 200.00 to mill an intake.
My porter charged me $175.00 Canadian to mill mine .005. KimWhat the quote on that mill job? I got a set that needs a clean up and may as well get it to where I want it, as well as the intake.
If this is a fresh build, why not leave the heads and intake alone and just use other pistons.My machine shop can cut up to .020 a pass, so figure it out from there. Then I cut the intake side to keep everything in the right relationship. Evidently there is a wide spread on milling costs per machine shop. I never tried to cheap out on performance builds. You have to do what it takes at your level.
Just spit balling
... Notice how far the bolts are outta wack. Kim
Heads always "warp" a bit so while you are milling them flat again, I just would go the whole .020. Then mill the intake side .019 to keep the head surfaces in the right relationship to each other. You only have to do this once as they don't "move" much after all those years and thermal cycles. I never mill an intake manifold, unless it is out of spec. I still have High Performance blocks from 273's, a 318 Magnum, and 340's that will clean up with a hone, so I will reuse the pistons in those blocks. Those engines are not compression challenged, so I do not feel the need to add the extra expense of boring and pistons. I assume the OP is keeping his short block as is or is just freshening up the motor.
No, the intake sides get closer as the head if effect gets shorter and makes the V narrower. That’s why u mill the intake sides of the heads or the intake manifold sides. Kim
