'teen machine
I don't mean to bust nobody's chops but, where is everyone getting the info that putting 360/340 heads on a 318 will drop the compression as drastically as they claim??
It's all in the measurements. If everything but the heads remain the same, the extra cc amount in the larger chambers of the 340/360 head reduce the compression. A nominal cc amount of a 340/360 head is 72 cc's. However, they can be 2 - 4 cc difference from head to head.
In order to maintain the compression ratio of between the 2 heads, the larger chambered head must be milled down to match the smaller chambered head.
Less area to squeeze in the same volume of air and fuel intake when the piston goes up will raise the ratio.
Depends on the year but I think around 60-62. Typical 340/360 generally are 72-76 depending on the casting and the valves.
the stock set of #675 heads that I pulled off my 318 'steel head gaskets still 'factory' measured 68cc.....i then checked another set that were only lightly surfaced...=67cc
the factory J heads off my duster measured 72cc..
I have the kit to measure and have to know so..
So if you were to put your 340 J heads on your 318 you'd drop your compression ratio .3 of a point...I’ve heard lots of guys claim more than 6 times that amount!
So by my calculations a 318 with .030 thick head gaskets and 62cc heads makes around 8.5:1 compression.
The same engine with 72cc heads makes around 7.8:1.
I've heard lots a guys say putting 360 heads on a 318 will drop you compression to 6-6.5:1.
Even 84cc heads make over 7:1!
What calculator are you using to come up with those figures and what head gasket bore are you using and are you accounting for valve reliefs and/or dished pistons? I ask because using this calculator
http://www.csgnetwork.com/compcalc.html
which seems consistent with all others I've used, figuring a .039" thick head gasket with a 4.08 bore (std. replacement head gaskets currently available as a regular order), 10 cc's for valve reliefs (no dish), pistons .080" in the hole, and 67 cc chambers I come up with 7.44 to 1 compression. Make the chambers 72 cc's (the smallest stock 340/360 chambers I've ever measured) it drops to 7.13 to 1. I have never measured 318 head chambers so I'm taking Justin's word for it that they are about 67 cc's.
True it only drops the compression .3 using those figures. But I think your in error with your calculations.
In addition to fishy's math, and Justin's notable mention of head gasket thickness.
Going from a stock gasket to a thicker one will ad even more of a drop in ratio. This is where we here at FABO say not to do a 360 head swap on a teen. Even more so when the pistons are left stock and the head doesn't get milled.
Now, combine the larger valves which can and normally do cause a lazy air flow. True, it flows more air, but! You will need to get the RPM's up in order to benefit for the potential gain.
So, in the combo of possible problems, not only did you loose some compression when you should be looking for a gain, but the bigger valves moving air slowly dropping fuel out of suspension also lowers HP and torque. This now create's a lazy, soft bottom end and a slower car.
The stock engines already suffer from a ratio to low for use with modest cams never mind a decent street cam. Remember that a typical performance cam has more over lap bleeding compression. Adding a larger cam and the 360 heads just kills the performance of a 318.
Often I recommend staying with the 318 head and porting it out some and sometimes advise on the use of 360 valves. (1.88 - 1.60 ) For the cubic inch size of the engine, a hot street teen can be built with the stock heads ported w/larger valves. While this is a more expensive approach than a straight swap to a 360 head, the performance jump is worthy.
IF there is any question to this or doubt, way back when MoPar had in there catalog a ported 318 head with the note of out performing the 360 head to the tune of 55 HP.
HELLO! 55 HP!
There is a time and place for a 360 head on top. It is build dependent, application dependent.
..but the compression will not suffer as bad as some of us have been led to believe.
The reason our numbers are different is because I didn't add any valve reliefs.
I was using the summit compression calculator, and if I put in 10cc for valve reliefs I come up with 7.48 with 67cc heads and 7.18 with 72cc heads.
Do you need valve reliefs with the pistons 80 thou in the hole??
