Header fitment rant, Doug's
Mopar Exhaust Systems
  1. MOA
    MOA Well-Known Member
    341
    151
    Feb 23, 2016
    CA
    Local Time:
    9:49 PM
    How is it that they've been making these headers for years and still haven't revised them to not interfere with the steering?
    A body with original 318.
    I cut a 1/4" shim to lift up the drivers side, haven't installed it yet so I'm not sure if it will be enough.
    Exhaust tube for #3 is a tight bend, why didn't they do the same on #5? It would of fixed this problem. May create a different problem, but I dont think so.
    I'm getting tired of things not fitting properly, really frustrating! I'm a retired metal worker, I get my shit right, why can't they? I shouldn't have to be shimming anything on this.
    Just a mild rant.....
    • Agree Agree x 4
    • Like Like x 2
    • RustyRatRod
      RustyRatRod I didn't do it. FABO Gold Member
      69,123
      43592
      Jun 7, 2010
      Georgia
      Local Time:
      10:49 PM
      I cannot agree more, but as long as people keep "making them work" instead of complaining or returning them, they'll not change a thing.
      • Agree Agree x 5
      • Like Like x 1
      • mopowers
        mopowers Well-Known Member
        5,331
        2360
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        7:49 PM
        With as tight as these cars are in that area, once the variability of factory tolerances are accounted for, it's gotta be pretty tough for a manufacturer to make a long tube header to fit every single A body out there. I give them the pass on this one and chock it as part of the process of building one of these cars.
        • Agree Agree x 2
        • dukeboy_318
          dukeboy_318 Our Lives, Our Fortunes and Our Sacred Honor. FABO Gold Member
          42,376
          18227
          Jan 19, 2007
          1600 Pennsylvania Avenue, Washington, D.C.
          Local Time:
          10:49 PM
          What is odd is Doug's headers are very often praised for their fitments.
          • Agree Agree x 2
          • Like Like x 1
          • RustyRatRod
            69,123
            43592
            Jun 7, 2010
            Georgia
            Local Time:
            10:49 PM
            I have nothing but good things. I had them on my 65 and they installed easy and fit great. I see others have the same experience and yet others......not so much. But I have never seen a Chevy guy complain about a 99 dollar set of headers fitting in a 70 small block Camaro.
            • Like Like x 2
            • Agree Agree x 2
            • dukeboy_318
              42,376
              18227
              Jan 19, 2007
              Local Time:
              10:49 PM
              Agree. Hell, I'm having issues with my factory manifolds on my poly hitting the steering box, and they are the very same ones with the very same engine and mount I pulled out of the thing. Sometimes things need so tweaking to get to clear.
              • Agree Agree x 3
              • Disagree Disagree x 1
              • RustyRatRod
                69,123
                43592
                Jun 7, 2010
                Georgia
                Local Time:
                10:49 PM
                I had Schumacher mounts on mine. I've read somewhere that the Dougs were actually made with the Schumacher mounts in mind. I don't know if that's true, but I do know I had no issues with fitment.
                • Like Like x 1
                • Thanks! Thanks! x 1
                • dukeboy_318
                  42,376
                  18227
                  Jan 19, 2007
                  Local Time:
                  10:49 PM
                  could be. I'm just saying its easy to not get things in right and that affects the clearance of everything else. That polara poly, all I did was raise it up, put it back down in the same spot and it lost its alignment.
                • RustyRatRod
                  69,123
                  43592
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  10:49 PM
                  Certainly with all the variations between car to car.......even in the same year, that could account for a lot of the fitment differences right there.
                  • Agree Agree x 3
                  • MOA
                    341
                    151
                    Feb 23, 2016
                    CA
                    Local Time:
                    9:49 PM
                    I have the schumacher poly mounts installed.
                    • Like Like x 1
                    • jos51700
                      jos51700 Hemi Orange you glad it isn't a political avatar?
                      5,532
                      2244
                      May 24, 2009
                      Bel-Ray
                      Local Time:
                      9:49 PM
                      I had no major issues with mine, other than re-clocking the Z-Bar.
                      I also had new engine mounts. How old are your mounts?
                    • Ottmundr
                      Ottmundr 68 Fastback
                      7,464
                      11509
                      Oct 5, 2012
                      Sonoma
                      Local Time:
                      7:49 PM
                      The regular ones or the polylocs? I figure I'd spend the extra on the polylocks when I do order them. The difference is only around $150 if my creaky brain remembers right.
                    • RustyRatRod
                      69,123
                      43592
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      10:49 PM
                      I honestly don't remember. It was whichever ones come in the slant to small block kit for the Early A. Probably just the regular ones. This was about 1998.
                      • MOA
                        341
                        151
                        Feb 23, 2016
                        CA
                        Local Time:
                        9:49 PM
                        Mine are new poly locs.
                      • dano
                        dano Evil Handy Man
                        3,615
                        1482
                        Aug 22, 2005
                        Gresham, Oregon
                        Local Time:
                        7:49 PM
                        My fix was a B-Body Drop in Flaming River tilt column. Everything clears now. Tilt was on my want list so the headers accelerated that to a need. This was with the Power box. They cleared my Manual box and steering just fine.
                        I agree though, it shouldn't take a $550 Column to have these fit without modification or other costly accessories.
                      • MOA
                        341
                        151
                        Feb 23, 2016
                        CA
                        Local Time:
                        9:49 PM
                        Question for those that had no interference with steering.
                        If the number 5 tube was routed closer to the block, 1/2" or so, would that have caused a problem?
                        It would solve my problem, actually a common problem from what I've read. And if it didn't cause a problem for those they worked for, it would solve 99% of the fitment issues. Why not revise the part?
                        For those that are considering headers, don't expect them to fit without modification, that is my opinion.
                      • 72bluNblu
                        72bluNblu FABO Gold Member FABO Gold Member
                        11,353
                        5911
                        Nov 28, 2008
                        NorCal
                        Local Time:
                        7:49 PM
                        No one installing headers on an A-body should expect them to fit without modifications. I don’t think that’s a secret.
                        Doug’s and TTI’s are by far the best options, and I have seen both of them fit some cars without any modifications. But I have also seen both of them require modifications on cars that, at least on the surface, were set up identically to cars that they fit without mods.
                        There are significant body tolerance variations on these cars. And there are production tolerances on Doug’s and TTI’s too. And there are production tolerances on engine mounts, and everything else that has an effect on how well those headers fit. That’s just how it is, you can’t make anything without some level of production variation. The more modifications you make, the more interference issues you’re likely to have.
                        • Agree Agree x 5
                        • Like Like x 1
                        • mbaird
                          mbaird mbaird
                          6,829
                          3550
                          Dec 10, 2005
                          boise, Id
                          Local Time:
                          8:49 PM
                          This is why I drop the car onto the engine/trany/k-member / header assembly.
                          That way I can get everything fitted in the open beforehand.
                          • Agree Agree x 3
                          • Like Like x 1
                          • RustyRatRod
                            69,123
                            43592
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            10:49 PM
                            That's an unfortunate truth. BUT, the torsion bar suspension AIN'T nuthin new. It's been around since what........58....59? HELLO? Plenty of individuals have made nice custom headers on their own. It'd be nice if a header company could do it.
                            • Like Like x 2
                            • Agree Agree x 1
                            • TrailBeast
                              TrailBeast AKA Mopars4us on Youtube
                              21,488
                              9166
                              Mar 11, 2011
                              Arizona
                              Local Time:
                              8:49 PM
                              Someone once asked what the difference was between cheap and expensive headers was, and my answer was "It hurts a lot more to make expensive headers fit."
                              • Like Like x 5
                              • MOA
                                341
                                151
                                Feb 23, 2016
                                CA
                                Local Time:
                                9:49 PM
                                That's exactly what I'm doing. I dropped it back out to deal with this issue.
                              • RustyRatRod
                                69,123
                                43592
                                Jun 7, 2010
                                Georgia
                                Local Time:
                                10:49 PM
                                I would give Dougs a call and tell them your exact issues. They may have some suggested fixes.
                                • MOA
                                  341
                                  151
                                  Feb 23, 2016
                                  CA
                                  Local Time:
                                  9:49 PM
                                  I sent them a message, apparently they don't take calls.
                                • MOA
                                  341
                                  151
                                  Feb 23, 2016
                                  CA
                                  Local Time:
                                  9:49 PM
                                  At this point, this car just makes me laugh.
                                  Absolutely nothing has gone together without modifying it, nothing. ie, everything about this car is a pain in the ass. Hahahaha
                                  • Like Like x 3
                                  • Agree Agree x 1
                                  • 67 gt
                                    67 gt A Wog boy who loves his Mopars ! FABO Gold Member
                                    1,147
                                    835
                                    Nov 9, 2011
                                    Down under
                                    Local Time:
                                    2:49 PM
                                    I will post some picks up tonight as they are on my laptop the mods I needed to do as no 7 tube was hitting steering column and needed to be hit half the size to make it fit I ended up cutting sections on tubes 5 and 7 and swapped them around couldn’t believe how much clearance it gave me .
                                    • Like Like x 1
