the tti instructions tell you you need to put both in from underneath. put the pass side in 1st, its easiest if you have the car jacked up as high as possible...i dont know why, it just worked like that. the motor should basically be lifted up as high as you can go(i did it with trans attached to engine. its a tight fit but can be done.
