Header suggestions???
jeremiah2146fa
Grayland
I have a 1974 duster with what appears to be a 1967 valiant 273 k-frame, a 1974 360 out of a motor home and power steering. There appears to be NO room between the existing 318 manifolds that are on it and the steering gear box (which is a '74, I replaced it after the original broke).
Any idea what headers might fit? I'm a little skeptical about fit.
I am running Hedman headers with power steering in my 68 Barracuda. The headers clear everything just fine.
I would recomend that you pull the steering column to install them though. It makes it some much easier than jacking the engine out of the mounts and trying to wrestle them in and will likely save you an hour or more of frustration. This recomendation would be for any brand header.
