headers for a 77 360 in a 72 dart
ep41
Member
Does anybody know where I can find headers that will cover the emissions ports on my 1977 360 that is in a 1972 Dart?
Assuming they aren't clogged shut, you can plug the air injector holes under the exhaust ports with small allen head screws, or epoxy. If somebody is running later heads, say from the mid 80's on, with the air injector tube ports on the rear of the heads, I plugged those by taking a short section of the tubes, beating them flat and having them brazed to make sure they didn't leak. Can't remember if they can be plugged with small plugs mine was stil in a 88 D100 when I did it.
Hope this helps,
Alan
