HEADERS WITH A 4 SPD
A/MP
The 2A's that I have are 1 7/8 fenderwell headers/auto. Clearance is no issue. Found another '65 with a 273 and auto trans. Was thinking a 4 spd with in the frame headers and a mild build 273. Keg of worms? Thanks
dougs, TTI or spitfire
having run the gamut on all of them (and made a set) i'd probably choose dougs.
Yup- Doug's, Tti (read the specs and order the small port mod, and linkage mod), and Sanderson.
Can I assume a heat shield(starter) for certain?
if you can fit one, sure.
i didn't run one in my 64 or either of the 65's and only heat soaked the starter once-- while waiting in line for a car show, so basically the torture test to end all torture tests.
