Headers with HDK Torsion bar kit.
TurboGLH
CT
I'm finishing up on my motor install, I also installed HDKs torsion bar eliminator.
Currently running Hooker 5303 multi-piece headers. I had to massage the #2 tube where it was in contact with the pass side bracket that supports the rear of the LCA.
Drivers #7 is a whole different matter, the tube makes a fairly convoluted path to dive around the steering and the torsion bar. Unfortunately it runs right into the same bracket, but no amount of tube dimpling will fix it.
I've got two options, cut and weld the rear tube, or different headers. I'm almost 100% on modifying this set, but I'd like to know what other people are running with a similar setup. Just so I can take a look and make the right decision.
