moparsteel
New Member
so im about to dump 650 buck on a set of dougs headers so my 70 duster wont bottom out any last minute suggestions??
Get the TTI';s no bottom out, super fit
Tubtar,no need to take out the tortionbars to install TTI headers,all it takes is to read the instructions,use alitle comon sense and hope the car was built right in the first place. any specs on that engine,i suspect its a W-something..
Somebody correct me if I am wrong , but I was looking at a set of Dougs in a car last week end.....slip fit tubes and mini starter required.
TTI's for some reason I am thinking the torsion bars need to be removed , or maybe just on one side to install.....I seem to recall reading this when i was shopping for a set.
I had Hooker Super Comps in an early A and one tube goes outside the fender well........not easy until you have done it a few times.
My last set was home made and with an AlterKtion and much of the inner fender removed , which opened up a whole new series of issues.
O.K. , I thought I read that early A's had to route the torsion bars through the headers.
My deal is a 405 inch W9 / R-3. Fairly mild solid roller 264 @.050 and .664 lift , and 12.85:1 , built for E-85 and occasional street use.
I was going to dyno it this summer before it went in the car for the last time , but I have had so many set backs since I started this deal that I lost all patience. I will tune it on a chassis dyno as soon as I get it finished......hopefully in time to get a couple months of racing in before the snow flies.
