Heat Cycling Tires
64physhy
Weatherford, TX
I've seen Heat Cycling offered by a couple tire places for drag radials. What is this,what does it do, and is there a way to DIY?
Sounds to me like driving around a while long enough to get them heated up, maybe a burn-out, and let them cool down completely.
Heat cycling for drag radials..lol..sure,pull into the water box get them wet, pull forward do your burn out, pull forward make your run.. cycle completed,come down return road repeat process...
What you need is some Pimp juice.It works
You boys have any idea how fast this 'ol thang is?
I dunno but I've seen that pu plenty on youtube. Also saw it on Pinks. Might have been Kansas?
It hauls ***! Not bad fo0r a chabbie.
