Heat riser bushing size?
Slant 6 Engines
  1. 1963dartgt
    1963dartgt FABO Gold Member FABO Gold Member
    780
    316
    Nov 7, 2015
    Kansas
    Local Time:
    6:47 AM
    So at some point before i pulled my motor i havd an exhaust leak. I narrowed it down to the heat riser shaft bushing. Mine is gone does anyone know what size it is or where i can get a complete setup. Taking it off all the way is out of the question as it works great otherwise. Thanks.
  2. Kendog 170
    Kendog 170 Let the boy go !
    1,104
    696
    Mar 10, 2016
    Tewksbury Ma.
    Local Time:
    7:47 AM
    I thought I read someone sells a rebuild kit but can't find it.
  3. Kendog 170
    1,104
    696
    Mar 10, 2016
    Tewksbury Ma.
    Local Time:
    7:47 AM
  4. Charrlie_S
    Charrlie_S Well-Known Member
    2,932
    759
    Oct 17, 2005
    Silver Springs, FL
    Local Time:
    7:47 AM
    That is for a V-8. The repair kit for the slant six, has been discontinued for many years
  5. Kendog 170
    1,104
    696
    Mar 10, 2016
    Tewksbury Ma.
    Local Time:
    7:47 AM
    Opps! My bad.
  6. Charrlie_S
    2,932
    759
    Oct 17, 2005
    Silver Springs, FL
    Local Time:
    7:47 AM
    No problem. I ordered one for a V-8 several years ago, thinking it would work, for a slant six.
  7. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    59,774
    28120
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    7:47 AM
    Try Martin at Arizona auto parts. Maybe Or measure it and find a oil lite bushing that will work. Need to do mine also.
    • Like Like x 1
    • 1963dartgt
      780
      316
      Nov 7, 2015
      Kansas
      Local Time:
      6:47 AM
      Thanks everyone,ill keep an eye out for an nos rebuild for it. Maybe ill get the caliper out and measure and buy a small assortment of bushings to see if i can get something to fit.
      • Like Like x 1
      • 1963dartgt
        780
        316
        Nov 7, 2015
        Kansas
        Local Time:
        6:47 AM
        Just to update if someone ever looks this up in the distant future. On my stock unmodified 63 exhaust manifold the bushing size is 5/16ths I.D X 3/8 O.D fit great just put a little silicone on the outside to hopefully keep it in.
      • Naplm00
        Naplm00 Well-Known Member
        185
        38
        May 20, 2019
        Bay
        Local Time:
        4:47 AM
        Im assuming you have to remove the shaft to remove the bushing and replace? mine is nearly seized solid
      • 1963dartgt
        780
        316
        Nov 7, 2015
        Kansas
        Local Time:
        6:47 AM
        Yes mine fell out on its own. I was just gonna remove the whole thing but since i drive the car in almost zero degree weather i figured id try and save it.
      • Naplm00
        185
        38
        May 20, 2019
        Bay
        Local Time:
        4:47 AM
        good to know ! was thinking something like this would work
        McMaster-Carr
      • 1963dartgt
        780
        316
        Nov 7, 2015
        Kansas
        Local Time:
        6:47 AM
        Thatll work. I walked into fastenal told them what i needed. They handed me a loose sleeve and i handed them a couple bucks. Easy as pie.
        • Thanks! Thanks! x 1
        • slantsixdan
          slantsixdan =..=
          6,645
          1812
          Jan 7, 2007
          Vancouver BC
          Local Time:
          4:47 AM
          That silicone is going to fricker-fry into a cloud of smoke (in the air) and gritty ash (on your manifold) shortly after you start the engine. If you're relying on it to hold your new bushing in placeā€¦it's not going to happen that way.
        • Naplm00
          185
          38
          May 20, 2019
          Bay
          Local Time:
          4:47 AM
          Maybe a tiny stake or two with a sharp chisel ?
        • 1963dartgt
          780
          316
          Nov 7, 2015
          Kansas
          Local Time:
          6:47 AM
          Sorry i guess i used the term "silicone" to loosley. It actually rutlands stove gasket cement. Ive used it to repair a crack in an old pot belly stove years ago. Figured if it worked then itll work to hold in a little bushing. Good for up to 2k degrees of roughly 1090c.
        • mcode
          mcode Well-Known Member
          233
          42
          Jul 6, 2009
          Local Time:
          6:47 AM
          dynamicrenovation.net has kits. Good people, good parts.
