Hello, working on a 75 valiant need help with door linkage
JoeShmoe
New Member
indiana
The door doesn’t unlock from the outside but unlocks from the inside. When I pull the linkage rod connecting to the outside door button down it unlocks. So the rod is not getting pulled down enough with the press if the button, is there a type of adjustment that changes how far it gets pulled down or will I have to bend the rod to move down farther?
Thanks
You might wanna ask this in the Mopar Body and Trim or Mopar Interiors forum.
