cchrishefish
Sounds like what you've got is a conventional (points type) distributor into which has been installed a Pertronix electronic conversion. The plastic wheel contains six magnets; if you lift it out of the distributor you'll find it's sitting atop a hexagonal metal cam which used to bump breaker points open before the points were replaced with the magnetic switch and the cam was covered with the magnet wheel.
Thanks Dan, is this method used often to covert these over in modern times?
