help-bucket seats in 68 barracuda
68CUDAGUY
this may be a dumb ? to some but i gotta ask.did they put diff floor pans in for bucket seats and bench seats?mine has a bench seat and mounts on each side on a raised tapered rail.do the bucket mounts have a raised mount on the inside to allow for the rail on the outside?I`M CONFUSED!#-o
if u look closely in the middle of the floor u will see the 4 divets on each side stamped for bucket holes...drill the holes and then weld square reinforement plates on
I've seen those reinforcement plates available somewhere but can't find them again. Simple 1/8 " plate approx. 3" by 4" with a 1/2 hole drilled through center. 4 required at inboard holes only. Factory rolled the forward edges. I'll get a pic if you want. Cheers
Here's what the factory replacements look like.
They can be purchased here.
http://www.tallzag.com/product/6776ABB/A-Body_67-76_Bucket_Seat_Braces.html
I bought them when I converted from bench to buckets, but they are not necessary for a driver. They can easily be fabbed from scrap metal for next to nothing.
thanks for all the info guys,you`ve been a great help.AL
