Help cooling 408 stroker
Heating / Cooling / AC
  1. fsoria1315
    fsoria1315 Member
    14
    1
    Aug 13, 2020
    California
    Local Time:
    1:38 AM
    I have a 69 Dart with a 408 stoker currently have a 22 inch Champion 4 row radiator and a 16 inch stage 2 Champion cooling Fan 2200 CFM. Car still runs hot and need some advice what I can do for more cooling. I only have little more then 2 and a half inches from radiator to pulley. What are my options?
  2. furyus2
    furyus2 Well-Known Member
    2,178
    673
    Oct 30, 2010
    weeki wachee fl
    Local Time:
    4:38 AM
    I don't think that's enough cfm. Choices are get a Mechanical fan, and shroud, or get higher output fans, and an electric fan shroud $$$.
    • Agree Agree x 5
    • Like Like x 1
    • fsoria1315
      fsoria1315 Member
      14
      1
      Aug 13, 2020
      California
      Local Time:
      1:38 AM
      I put in a the electrical fan with a switch because it was heating up with the mechanical fan in stop and go traffic. I figured its not enough CFM but i have so little space dont know what to do.
      I was thinking of getting a 2nd electrical fan as a pusher for the front side of the radiator and just offset both fans?
    • furyus2
      2,178
      673
      Oct 30, 2010
      weeki wachee fl
      Local Time:
      4:38 AM
      The pusher fan can cause an obstruction to air flow. 2 smaller fans with higher output would be better. Should give room for the water pump pulley. Does the temperature come down when driving?
      If so, a Mechanical fan with a shroud will help. What temps are you seeing?
      • Like Like x 1
      • mopowers
        mopowers Well-Known Member
        4,933
        2015
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        1:38 AM
        What are the diameters of the pulleys?
        • Agree Agree x 2
        • fsoria1315
          fsoria1315 Member
          14
          1
          Aug 13, 2020
          California
          Local Time:
          1:38 AM
          Any options that you might know of that has 2 smaller fans? When its hot out and my drive is climbing a hill it starts to run hot around 215-220 ish then starts to cool down once I level out runs around 200-210.
        • furyus2
          2,178
          673
          Oct 30, 2010
          weeki wachee fl
          Local Time:
          4:38 AM
          How about when sitting idling?
        • fsoria1315
          fsoria1315 Member
          14
          1
          Aug 13, 2020
          California
          Local Time:
          1:38 AM
          Haven't let it sit in this heat as it was running hot when I was driving it, but I will let it sit for a while and see how it does.
        • kursplat
          kursplat FABO Gold Member FABO Gold Member
          3,479
          2344
          Aug 24, 2010
          so cal
          Local Time:
          1:38 AM
          how thick is the radiator? i'm trying to figure out why you don't have more room. how thick is the 4 row?
          that's with March pulley's and a Hayden 2947 clutch
          • Like Like x 1
          • kursplat
            3,479
            2344
            Aug 24, 2010
            so cal
            Local Time:
            1:38 AM
            mine is a 3 row, tank is 2 3/4" and the core is 2 1/2"
          • kursplat
            3,479
            2344
            Aug 24, 2010
            so cal
            Local Time:
            1:38 AM
            see if Champion will swap it for a 2 or 3 row. then you can get a Contour fan setup in there
            • Agree Agree x 1
            • fsoria1315
              fsoria1315 Member
              14
              1
              Aug 13, 2020
              California
              Local Time:
              1:38 AM
              My 4 row radiator is 3 inches thick. I kept the car running right now its about 98 degrees outside no sun but temp just kept slowly climbing even with the fan on. So might have to swap the radiators like you said for a 2 or 3 row radiator and get better dual fans
            • jonn6464
              jonn6464 1970 Duster
              506
              341
              Mar 29, 2017
              Weatherford, TX
              Local Time:
              3:38 AM
              A few things here..
              -Personally, I don't feel 210-220 is too hot. I have a few muscle cars and 220 puts the needle straight up and down on the factory gauge, which would suggest that the factory felt that temp was ok.
              -If you want to have better cooling, get rid of the 4 core rad. Yes, I know it sucks to shell out $500 for another rad. But, the key to cooling is surface area. Get a 2 core rad with 1.25" tubes. That way you have more fluid being exposed to cooling air flow. You will see a big difference.
              -Are you running a 160 or 180 thermostat? If you have a 180, try switching to 160. This will allow water to start flowing at a lower temp and begin the cooling process sooner.
              -How is your fuel to air mixture? Dropping more fuel into the cylinder which causes a hotter burn. You can drop 10 degrees just with a carb adjustment.
              • Agree Agree x 3
              • Like Like x 1
              • BrianT
                BrianT Let's go!
                5,520
                1256
                Mar 13, 2007
                Kansas City, Mo
                Local Time:
                3:38 AM
                I have a 3 core Champion radiator with their two 12" fan kits and my 408 runs in the 200-210 range pretty regularly. I have the early version where they used the crap Chinese eBay fans. Now their kits are offered with the 12" Spal fan upgrade which is a HUGE CFM difference. I'm going to try and change out my fans and see if I can't keep the temps under 200 degrees.
                • Like Like x 1
                • Plymouth 65
                  Plymouth 65 Floorable Deplorable
                  1,218
                  1133
                  Jun 27, 2016
                  Mich
                  Local Time:
                  4:38 AM
                  I would run a high flow water pump and make sure the pulley diameters were such that you overdrive the water pump slightly. 65'
                  • Agree Agree x 1
                  • fsoria1315
                    fsoria1315 Member
                    14
                    1
                    Aug 13, 2020
                    California
                    Local Time:
                    1:38 AM
                    Apperciate all the info gentlemen. I'm gonna go get a 2 row champion radiator on Thursday and then order the contour dual fans to install it.
                  • jonn6464
                    506
                    341
                    Mar 29, 2017
                    Weatherford, TX
                    Local Time:
                    3:38 AM
                    Sounds like a man with a plan! Whatever you get, just confirm that the tubes are 1" at a minimum. 1 1/4" would be better.
                    • Agree Agree x 1
                    • kursplat
                      3,479
                      2344
                      Aug 24, 2010
                      so cal
                      Local Time:
                      1:38 AM
                      decided how you want to run them? on / off switch through relays, Dakota Digital (or equivalent) though relays, or PWM?
                    • fsoria1315
                      fsoria1315 Member
                      14
                      1
                      Aug 13, 2020
                      California
                      Local Time:
                      1:38 AM
                      Already have a relay installed with a 180 sensor also attached a switch as well.
                    • fsoria1315
                      fsoria1315 Member
                      14
                      1
                      Aug 13, 2020
                      California
                      Local Time:
                      1:38 AM
                      Temp has gone up to about 230 in a hot day and climbing a hill, cooled down to about 220 just cursing it. I'm picking up the 2 row champion radiator tomorrow, ordered the dual contour fan that ships on the 21st because its out of stock, once I install all that I'm gonna take it to the shop to get the carb adjusted.
                    • 383Scampman
                      383Scampman Well-Known Member
                      1,667
                      880
                      Nov 24, 2013
                      New Hampshire
                      Local Time:
                      4:38 AM
                      I've done a 6 month research on what it takes to cool a performance Mopar . Several issues arise that is common to b.b. & s.b. . These are my results : the block and heater (if you are using one) must be clean . sounds basic but needs to be said . I would start with the least expensive upgrade and go up in cost from there . Next in line is a high flow thermostat (affordable) . going on from there is a high flow water pump . moving up in cost is an aluminum radiator (spendy) . Radiators come in all thicknesses but for this discussion we'll stick with 22". I have found that 2 rows of 1" or 1 1/4" tubes cool best . You get increased capacity and good air flow . The diameter of the pulleys must match . this is important for pump life . Hoses : use hoses designed for your car , not the universal convoluted ones . If you are not using a shroud , then get a 18" fan with a clutch if you have room . If you use a shroud , use a 16"15" fan . Belt : use a 5/16" wide belt , not a 3/8". the 3/8" belt doesn't set in the pulley deep enough and could fly off . Coolant : 50/50 green coolant with distilled water (not tap water), distilled water is cheap . Add water wetter and/or water pump lube as per directions .
                      One final thought : LA/BB/GenII Hemis were never designed to run at high temps (195*+) the cooler the better . Magnum/GenIII Hemis are designed to run at 195*+ and higher . Hope this helps , Tom
                      • Agree Agree x 1
                      • Thomas Dennis
                        Thomas Dennis Well-Known Member
                        221
                        101
                        Oct 31, 2019
                        Hudson FL
                        Local Time:
                        4:38 AM
                        Is it possible that your rear end gear ratio is too steep
                      • j par
                        j par Well-hung Member
                        24,688
                        12975
                        Jul 2, 2014
                        Portland Oregon
                        Local Time:
                        1:38 AM
                        410 stroker.. $160 cheap Summit 2 core radiator... Big as I could fit ( not all that bigger than stock). Quality (meaning over 2500 CFM (thin as I could buy) 16in puller fan (of set to the driver side to fit).. with a thermal controller shut to 180°..
                        No thermostat... 1 to 1 Drive on a factory water pump..
                        Never seen over 205 and generally don't see anyting but 195 on the hottest days...
                        And if I can maintain 40 miles an hour or more the fan doesn't even come on...
                        For less than having someone tune your carburetor you could probably buy a wideband O2 sensor for about a hundred and sixty bucks and tune your own carburetor... And you'd also know if it needed it or not...
                        To reiterate if the car can't maintain temperature at 40 miles an hour consistent then it's has nothing to do with the fan..
                        I also have to say before I added the big condenser radiator and a 12in electric Pusher fan the car would get down to 160- 170 on the freeway... Now even with that condenser and 12 inch electric Pusher fan in the way of the radiator when that 12in isn't running it still maintains 180 well moving down the highway. And definitely doesn't get / 195 when setting... Again it will have to be well over 95 degrees outside for it to get up to 200 or 205 (100° day) while at a standstill idling in traffic...
                        • Like Like x 2
                        • Agree Agree x 1
                        • kursplat
                          3,479
                          2344
                          Aug 24, 2010
                          so cal
                          Local Time:
                          1:38 AM
                          sometimes i wish these cooling threads were divided regionally. i don't know what part of california fsoria1315 is in but kansas, oregon and so-cal have different kinds of summer. i want mine to live, parked in traffic for an hour, with it 115' out.
                          j par, i like the deflectors :thumbsup:
                          • Agree Agree x 2
                          • Thanks! Thanks! x 1
                          • j par
                            24,688
                            12975
                            Jul 2, 2014
                            Portland Oregon
                            Local Time:
                            1:38 AM
                            We've had a string of 95 and upwards of a hundred degree days and those were the days that I tested... if you live somewhere where it's regularly 115 degrees we need to start another thread on why you would live in a place that's regularly 115 degrees...
