HELP DECODING 1968 Barracuda Formula S fender tag/data plate
FASTEDDIE1960
iowa
Hope someone can help me decode my data plate on my 1968 Formula S Please see photo (there is a 3 on line 4 underneath the X on line 5 Circled in RED) I have pretty much decoded the rest of the plate but can't seem to find anything about this #3..?
thanks very much
Are you original owner?
Special handling tag has nothing to do with "ordered"
the tag is original to the car it was special ordered by a customer that is what the U1 code on the data plate is. it was a sold car when built..thanks much i looked at alot of sites and couldn't find that 3 code..much appreciated.
The screw placement on the "Special Handling Car" tag makes it a 69+ tag, not original to the car.
If it was original to the car the two tags would share the middle screw.
Alan
Another reason to suspect a problem is that 3 under the X denotes clear glass, but A/C cars were supposed to have all tinted. The 1 under the S is A/C, and the hose is right there in the picture. So that looks legit.
If the glass is clear and date coded, you have a car that "shouldn't have been."
You could override the tinted glass with A/C. That’s why it’s coded.
thanks guys i will get this special handling tag removed . No idea why someone put it on but was this way when i bought the car.. thanks for the info
thanks is yours a 1968? any idea as to what the special handling tag means? special ordered? dealer?
That's a '69 fender tag. Don't believe that's legit either. Not mine. Copied that from another posting to show how the "extra" tag would be attached from the factory. Consensus was no A body ever came with them.
Rare Fender Tag,,,or Not???​
