Help decoding this 8 3/4
64whiteghost
Whatsup guys. Thank you all for the help so far.
Picked up this 8 3/4 on offerup for $100 its not an exact A body rear end. But it measures 53" from back plate to back plate. Its a 741 case. I plan on shortening this for my 1964 plymouth valiant .
I picked up a 489 3:23 sure grip. And would like to use on this 8 3/4. I want to know if it can be used on this rear end body.
All center sections can go on any 8 3/4 housing.
The axles need to have the correct splines.
The pinion yoke needs to have the correct U joint size for your drive shaft.
