help.. disc brake help needed
rmazess
cape coral florida
i have a caliper that i need to replace.. part number on the back.. or.. sort of the part # is 3880-585. I ordered one from a local parts store.. and the brake hose banjo bolt is in the wrong spot..(compared to what i have..can anyone tell me what this caliper 3880-585 came off of?
thanks
Post a picture of what you have.
Appears to be a "Slider" type caliper, from the A body line of cars, 73-76.
But there were two used.
73, 74, 75, used a 2.600 diameter piston.
76 used a 2.750 diameter piston.
Digging this thread up from the dead. OP if you're still on here what year and model did you wind up ordering? Ordered the one Summit said CPP recommended but it also came with the bleeder and hose in the wrong location and they don't seem to know what it's off of for their own kit. The one I need is the exact part number (3880 585) in your picture.
got one from autozone... it was off of a aspen/volare(i think) if you google the part #you should come up with a match.. if not let me know.. i will dig up what i found
Thanks man that looks like the one! Appreciate the help.
