Help! Electric washer switch dash location? Pics?
lee01
Cantley, Qc, Canada
My 71 Duster came with a foot pump washer system.
Now since i'm rewiring the car a-z i might be a good idea to go with a electric pump.
I wanted to know how were the button or switch, what it look like and were its located on the dashbord?
Anyone have a picture? Worth a thousand words :)
The washer switch is built into the wiper switch on cars with electric washers. Just push in on the wiper knob.
Easy if you have/get the correct wiper switch. It should have a terminal marked "W" (I recall), which sits fairly far from the others. You also need one that matches your wiper motor. Most were simple 2-speed. The variable-speed wipers had a much bigger wiper switch. You can find photos here and on e-bay.
One thing that confuses people on the wiper switches is that Mopar used the switch as a convenient terminal to connect 12 V power to other devices. Just follow the wiring diagram and don't worry about "why is my wire for ___ going to the wiper switch?"
