help getting correct gaskets
DusterBoy15
THE WISE(guy) MEMBER
san jose CA
i have a 76 block and magnum heads what gasket kit do i get so that everyhtings fine. will a fel pro gasket kit work for a 1976???
yup. Stock set will be fine. Be careful sealing the valve covers. LA covers will work, but you have to be careful that the gasket doesnt shift when you install them.
