Help ID Some Pedals?
BrianT
Here we go again...
Kansas City, Mo
I have a line on some pedals locally to convert my 67 Dart to a manual transmission. I'm not sure if these will work? Can anyone shed some light on the subject? Thanks!
Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
Look through there. My eyesight sucks this morning. Looks like there is the safety switch on them, so they would be 70+. The 67-73 are essentially the same with the addition of the safety switch in 70.
Any of the 67-76 a body pedals tend to work in the cars regardless of year. The pedal arms are different throughout the time frame.
Okay. Using the info from the Brewer's page these would be 70-72 pedals because they have the clutch switch on them? Brewer's doesn't say anything about clutch switches on any of their other A body pedals. Anyone else care to chime in?
The switches are different depending on the year, that one looks the same as the one on my '70.
If you want to know for sure, the switch bracket has a stamped in part number & date code.
It sounds like they will fit my 67 either way. I was worried that they might be earlier or late pedals that wouldn't fit. I'm going to go pick them up this afternoon and we'll look for part numbers on them. The guy has a complete A body 8 3/4 that I'm interested in getting a peek at also!
