Can anyone help me identify these brakes. The part number on the calipers start with a K-H, so I figure they must be Kelsey Hayes. They are a 5x4.5 pattern.
From looking at the style caliper, brake flex hose attachment to the caliper, upper control arms, spindles, everything appears to be 1973 and up, B body line of cars.
yup...late B...pin mount calipers. slider calipers on same uca would be F,M,J,R.
UCA is deff. iso mount k frame era part.
Good swap material, minus the uca assembly.
Front mount the calipers unless you want to clearance the A body lower control arm.
