Help, ignition starting backwards.
HardRockR
Member
Bismarck ND
Hi need some help. Last week car didn't start. After a week of switching starters, replaced the ignition relay and then found it was a bad ground wire. So now it starts but not when the key is turn in start position, it cranks and cranks but doesn't even try to start, only when you let it go does it fire up, any ideas.
The switch should send 12 volts to the ignition system on one wire in the start position and a different wire in the run position.
Sounds like the start position wire isn't working.
What car etc.. would help
Here's how Mopar start/ ignition switches work:
You have (normally, some dissent) dark blue, "ignition run" or "ign1" which is hot with key in "run" and supplies the top end of the ballast, the regulator, the field for isolated field (70 and later) alternators, the electric choke if used, and maybe the carb idle solenoid if used.
For starting, there are TWO separate circuits. When you twist the key into "start"
Brown is hot, which BYPASSES the coil/ ballast resistor, and provides a hot spark for starting
Yellow goes to the starter relay, and on auto cars or cars with clutch safeties, a second "push on" terminal of the relay must be grounded through the neutral safety or clutch safety switch, to fire the relay, which then fires the starter through the "square" exposed terminal on the relay.
So you brown is either unhooked, or the bulkhead connector is "losing contact" or there's a bad connection between there and the ign switch (connector at the column) OR the ign switch itself is bad on that circuit
You can download a free service manual right here:
http://www.forabodiesonly.com/mopar/showthread.php?t=132309&highlight=manual,+download
