Help me identify/locate this part for my 904
Transmission and Drivetrain Tech
  1. briwill70
    briwill70 Well-Known Member
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    1:47 PM
    Pulled a 904 out of my 65 Dart and found that the kickdown lever has snapped off. I've done numerous searches and can't find the part anywhere. It's a dual cable shift model.
  2. MoparMike1974
    MoparMike1974 FABO Gold Member FABO Gold Member
    2,655
    1887
    Jun 16, 2017
    Maryland
    Local Time:
    4:47 PM
    I have a valve body from a 65 727, probably the same part. $20 plus shipping and you can have the whole VB.
  3. CudaFactHackJob
    CudaFactHackJob FABO Gold Member FABO Gold Member
    1,357
    478
    Mar 17, 2016
    Hemet, Ca.
    Local Time:
    3:47 PM
    Can you remove the kd shaft and measure it?
  4. briwill70
    111
    30
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    1:47 PM
    I found one on ebay and they are shipping it to me. Also pulled the pump/clutches. Glad I did. Front clutches are toast, probably because they were driving with a broken throttle lever.
    • Agree Agree x 1
    • TrailBeast
      TrailBeast AKA Mopars4us on Youtube
      21,431
      9042
      Mar 11, 2011
      Arizona
      Local Time:
      1:47 PM
      Damn, that pressure plate is ALL busted up.
      Don't see that very often.
    • CudaFactHackJob
      1,357
      478
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      3:47 PM
      Weird that it's not discolored from heat. But I suppose if the reverse/high clutch wore down gradually, and reverse became delayed, then every reverse engagement would be extremely harsh (when it did finally engage at a high rpm). But anyway, 904 kits are extremely cheap, cuz now you're going to need an overhaul kit for the clutches; unless you scavenge them from the other trans....but you'll need that top plate, so might as well take it apart. I hope you checked the endplay before you pulled the pump. You'll need a pump gasket, front seal, pump o-ring, and pan gasket at a minimum. Those come in a $15 seal up kit; along with tailshaft housing gasket, speedo seals, kd shaft seal, etc. But you'll have to order the rear seal special.
    • CudaFactHackJob
      1,357
      478
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      3:47 PM
      That snap ring looks low in the drum. You could use the bottom pressure plate from the other forward clutch as the top plate and squeeze in another steel and friction. Always check the clearance with the forward drum.
