The car ran, started fine, idled a bit shaky but idled. It was gutless, and ticked when you got into it. Also the previous owner added a line on the balancer for timing, which was about 30 degrees off from the factory notch.
Any thoughts? Usually it's dot to dot correct?
Thanks in advance,
Robin
