racerdude5
So I have factory 10.98 discs on my car. The concern is that I may have to B-body caliper brackets that are for the same side. On the 11" brackets the casting number that is like 10 digits long is different by one digit at the end and both casting numbers face downwards when installed on the correct side. However on the 12" brackets that I got they have the same 10 digit (about) casting number but the 3/ digit number on them is different and when installed the casting number on one will face up and the other will facedown. Do B-bodies use the same casting for both sides? What's going on here?
