Help w/Bucket Seat ID
GTXperience
Orig Stealth Mod
Sacramento Area, CA
Does anyone have a clue what these are out of? I am not necessarily assuming that the seats and the tracks are out of the same car (but could be). They were in a second generation Dart. They appear to have been reupholstered so I don't know if you can go by the current pattern.
Those do look like A-body tracks but can't be sure without heigth measurements .
It looks like one of them has a broadcast sheet in the bottom. What does the VIN say?
It is not the 1970 or 1971 E-Body style.
The metal tags hanging from the seat bottom springs should have the part numbers stamped into them.
All the numbers are faded/washed out. Also, if I lifted the springs up, that build sheet would disintegrate into a hundred pieces. Thanks for the suggestion though - good eye.
Can you take a close up high resolution photo of the VIN section? I can make them out that way most of the time.
